KLX 250S Advice
I have not messed with any sprockets yet, but I would think if you are going to do much riding at 60mph or slightly faster, then you would not want to change the sprocket.
its already doing over 6K at 60mph in stock form.
If you are doing mainly slower speeds, or alot of actual offroading with it, then yes, that sprocket would certainly help.
I have the 13-45 sprocket setup, and I do 65 (actually 60 according to the GPS) and the RPM'S run at 7 and it will do it all day. Don't be afraid of rinning the bike up at that range. After all the best spot is 7-8 grand.
Gearingcommander says stock 14/42 setup for the 2006 KLX250 should do 60 mph at 5635 RPM; 70 mph at 6570 rpm; 80 mph at 7515 rpm.
With 13/42, 60 mph at 6070 rpm; 70 mph at 7080 rpm; 80 mph at 8090 rpm. It's a good site - check it out (http://www.gearingcommander.com/).
I was running stock a little over a month ago and the commander appeared to be very close if not right on while adjusting for the speedo error - checked with GPS speed and stock tach. Running 14/49 gears now or I would check.
is this speedo 80 or GPS 80? you might be surprised if you haven't checked via GPS...just sayin...
Im pretty sure my 09 is off allllmost 5 mph at 45 mph
WHY are these bikes like this? Seriously, why would a modern bike be off this bad?
I think its a bit ridiculous. I wouldnt care all that much, but this means its effecting the indicated mileage also. Which means even calculating distance and/or mpg is off.
