KLX 250 ( 300 ) camshaft mod by Marcelino
#72
Yes, you're correct to not necessarily trust Kawasaki or any other manufacturer's cam timing out-of-the-box. Most all of them use the "close-enough" method which is practically always...well...close enough. You have to slot the cam sprockets a tiny bit to achieve perfection usually, and for a bone stock engine this just isn't normally worth much effort. I was just thinking that precisely degreeing the cams in the scenario that you have discovered may be worth it. As the Web Cams info indicates, this can be a valuable tuning element. Like I said, not poo-pooing your effort here whatsoever.
Someone with a lot more tuning and model knowledge than I brought something to my attention. Apparently there may be a similar issue that occured with the Yamaha YZ400F/WR400F series and the YZ/WR 426 series cams as far as tuning the cam timing goes. I haven't started looking for it yet, but perhaps it would shed some light on Marcelino's approach in this case.
If you think Kawasaki was trying to tune the KLX engine for maximum performance , you´re wrong , this engine has a state of tune such that it can run reliable , on garbage gasoline , in any corner of the world and pass emisions too in the countries where is required too . The KX250 F is tuned for maximum performance , it has 35 HP , the 25 HP I´ve got on the KLX are nothing in comparacing with a KXF .
Before posting the mod in any forum ( spanish or english ) I´ve tested the bike in town , on mountain pases , on trails , on the highway and o the dyno for some 7-800 Km , nothing negative to report , just more stones and the same fuel consumption .
Before posting this mod I´ve had various frieds that told me I should make money with this mod . I didn´t listened to them , I´ve put it in the wild as free knoledge .
#73
Originally Posted by Marcelino
If we look at a KLX sproket we see that it has 34 teeth , that means one tooth corresponds to 720 degees / 34 teeth = 21.17 degres . Hmm we cannot move a tooth , it´s too much , it will make the angles 89 degrees...
Well , if we look CLOSELLY at a sprocket whe see that the distance between the two holes that correspond to " for INtake " and " for EXhaust " is two and A HALF teeth .
Well the solution is at follows :
For intake we give it 2 and a half teeth more advance by puting the screws in the position that corresponds to exhaust and then we retard the camshaft 2 teeth in the chain . The difference , as far as the cam is concerned , is a 1/2 tooth ( 10-something degrees )
For the exhaust cam it´s the same , but in the opposite direction : we retard the cam by puting the screws in the intake position and then we put the sprocket 2 teeth more advanced in the chain . This cam will de 1/2 teeth retarded ( 10.5 degrees ).
I´ll be on vacation all month in July and I´m considering taking my D-Tracker to my dealer to get this done.
#75
Thinking of doing only the intake tomorrow. See what happens. I am curious about cold and hot start, smooth idle and power.
I totally understand the setup, moving the cam by 1/2 tooth in the end.
OK stupid question. Could I move the chain by one tooth on the crank that results in 1/2 tooth on the cam?
Davied
Davied
#76
Looking at bikebandit.com, the camshaft sprocket has 32 teeth. Maybe it´s a typo.
34 teeth , no typo . When yo´ll open up you´ll see .
Could you go in more details on how to exactly "retard/advance the camshaft 2 teeth in the chain"? Does the piston need to be at a certain position before everything is moved around?
After you position your engine at TDC , remove the chain tensioner , the chain ( make sure it doesn´t fall) , remove the cams . Mark the position of your decompressor ( ACR ) , you will need to press it out and reinsert it 6-7 mm ( 1/4 ich ) rotated counter clock wise as you look at it .
For the intake shaft : take out the 2 sprocket bolts , turn the sprocket util the EX holes allign with the threaded holes in the camshaft , put the bolts in and tighten , use threadlock . When you put the cam back in you NEED to put it two teeth turned CCW as you look at the sprocket , on the left the IN mark is a little below the edge of the head , on the right of the sprocket the mark is exactly 2 teeth above the edge of the head . Look carefully at the fotos .
On the exhaust shaft is exactly the same , but on the opposite direction .
Move the bolts to the IN position and put the shaft 2 teeth rotated CW ( Clock Wise ) .
Reset your tensioner , install it and then turn the engine BY HAND a few times
to make sure everything is OK . Then you can recheck your new allignement .
Add gasoline and enjoy !
#77
If my thinking is correct, advancing the intake buys you more space. You are withdrawing the valve earlier in ralation to the piston that is speeding up the cylinder at the open valve, thus getting the valve out of the way even earlier than you were with the cam set up OEM...
On the other hand, you are right that the intake side is more secure than exhaust: the intake valve clearance is not affected by valve float, contrarily to exhaust side. Even though the engine is designed to operate without significant valve float up to redline, there might be a small amount at very high rpm. That amount increases with time, due to valve spring fatigue. The exhaust valve to piston clearance decreases when valve float becomes larger, because the piston is moving up when the exhaust valve closes.
Did I made that clear? I'm not sure I would understand myself if I read this back
Overall, I'm sure the timing Marcelino suggests decreases the piston-valve clearance for both intake and exhaust, but I would be very surprised if it became an issue. People are putting new bores with higher compression since a long time already, indicating the OEM design leaves ample room for improvements.
