KLX 250 ( 300 ) camshaft mod by Marcelino
Old 07-01-2013 | 10:18 PM
Klxster's Avatar
The photos of the ACR positioning are confusing, ignore them.
Follow the instructions on ACR reposition. ( 1/4 inch counter clock wise when facing the ACR. )
Alric - yes
  #422
Old 07-02-2013 | 08:26 AM
Richard Avatar's Avatar
Thanks - I'll plan on doing it that way then
  #423
Old 07-02-2013 | 08:43 AM
yankee99's Avatar
Alric - yes
Nothing confusing! Follow the original information and make sure before you start taking cams out your bike looks the same as the pics. You are most likely 180degree off or not at tdc... Remember putting it together wrong can damage your engine.i
  #424
Old 07-02-2013 | 08:38 PM
Klxster's Avatar
I had no doubt that I could perform the mod - perform it correctly and successfully.
Do not attempt this mod unless you are equally sure of your skills and equipment. There is no room for error.
Marcelino has provided all the info you need.
I read all 42 pages of this thread several times wanting to verify that the mod works. There was very little confirmation involving a stock klx250s but enough to get me to do the mod and make a determination for those still in the wings.
The mod works. Your bike will perform as it never has before. You will feel the power all the time and you'll not be able to keep that stupid smile off your face or your hand off full throttle.
Here is the proof - http://www.youtube.com/watch?v=iJEF5...ature=youtu.be
The particulars are in my previous posts.
  #425
Old 07-03-2013 | 07:58 AM
panaisnc30's Avatar
Hi!Has anyone done it to a European klx 250r 1999 model?
  #426
Old 07-03-2013 | 08:05 AM
Alric - yes
My bike seems to have a little too much compression when starting. (no cam mod yet). I know there was some info in this thread about what that means regarding the ACR position.
I'll have to re-read that part
  #427
Old 07-03-2013 | 08:07 AM
I haven't taken the bike apart yet.
Maybe you could clarify the OPs instructions vs photo regarding ACR's position in relation to the box cutter blade, half round circle etc?
I've had a motorcycle engine completely apart before to do a Powroll stroker - I just don't see his postioning photo jiving with what he's saying about it.
  #428
Old 07-03-2013 | 10:00 AM
  #429
Old 07-03-2013 | 10:45 AM
Arctra's Avatar
Originally Posted by Richard Avatar
Great little vid - thank you.
So, you just changed the exhaust cam and did nothing to the ACR - right? Any trouble starting the bike when hot after doing the mod?
  #430
Old 07-03-2013 | 11:11 AM
It's not my bike or vid.
Okay I found the OP's written description on page 8 of this thread:
Always when working on the timing put you engine to TDC , your cams should NOT be pushing the tappets .
After you position your engine at TDC , remove the chain tensioner , the chain ( make sure it doesn´t fall) , remove the cams. Mark the position of your decompressor ( ACR ) , you will need to press it out and reinsert it 6-7 mm ( 1/4 ich ) rotated counter clock wise as you look at it.
For the intake shaft : take out the 2 sprocket bolts , turn the sprocket util the EX holes allign with the threaded holes in the camshaft , put the bolts in and tighten, use threadlock . When you put the cam back in you NEED to put it two teeth turned CCW as you look at the sprocket , on the left the IN mark is a little below the edge of the head , on the right of the sprocket the mark is exactly 2 teeth above the edge of the head . Look carefully at the fotos .
On the exhaust shaft is exactly the same , but on the opposite direction. Move the bolts to the IN position and put the shaft 2 teeth rotated CW ( Clock Wise ) . Reset your tensioner , install it and then turn the engine BY HAND a few timesto make sure everything is OK . Then you can recheck your new alignment .
Quick Reply: KLX 250 ( 300 ) camshaft mod by Marcelino
