KLX 250 ( 300 ) camshaft mod by Marcelino
Old 01-24-2021 | 06:58 PM
SaltyDitchDr's Avatar
Once I get some decent weather I'm going to do the MCM on my other KLX, would anyone be interested, or think it would be beneficial, for me to make a video on how to perform the mod? Some common issues during the process etc?
  #1132
Old 01-24-2021 | 07:09 PM
greychinos's Avatar
Absolutely. I personally think videos for DIY instructions are way better than just a few photos.
  #1133
Old 01-24-2021 | 07:23 PM
Ok, will do. I've read through the majority of this post and the instructions that the two members have made which has been so beneficial, but there are no videos really. And a few common mistakes seem to pop up regarding this mod as well and I am glad I read through all of this or I could of seen myself making those mistakes. Looking at that stock chain tensioner.
  #1134
Old 01-24-2021 | 07:26 PM
greychinos's Avatar
Thank you, it's much appreciated.
  #1135
Old 01-25-2021 | 12:26 AM
I make the cure for that stock tensioner problem. PM if interested.
  #1136
Old 02-04-2021 | 12:38 AM
Default MCM video
Here's the video I made to help people with the mod. Please let me know if there's a better place to put it on the forum, and if there are any errors or misinformation in the video. I added the Google docs from Klxster and klx678 as well as credit to them for it in the video description.
Edit* Sorry I don't know how to not embed the video and just post the link.
  #1137
Old 02-04-2021 | 03:17 AM
Klxster's Avatar
Looks good to me..
There are omissions - work was done without footage - For instance, each cam has two bolts holding the sprocket on. When lined up at TDC, only one sprocket bolt is visible on each cam. Step One: Each cams' bottom bolt ( the one not visible when at TDC) should be removed completely. this is accomplished by rotating the engine (off of TDC) multiple times. Then the engine must be reset to TDC and each cam completed - one at a time - and secured with ONLY the top (visible) sprocket bolt. Once MCM success is visually confirmed, the engine can be rotated multiple times again in order to reinstall the bottom ( non visible ) sprocket bolts..
Peeps will have to be able to figure such things out for themselves. The "safety net" is to do one cam at a time. As long as no one ever attempts to do both cams at once, they should be able to always find and re-find the correct/proper cam/sprocket relationship at TDC.. .
With the current problem of the stock ECM programming killing off upper end HP, a properly done MCM is most important to the newer EFI owners. Until the detune is able to be defeated, the MCM + stock header+ performance slipon + lidless airbox + EJK fueler is the most effective mod combo. Making a "monster" motor from off idle to about 7500 - 8000 rpm..
  #1138
Old 02-04-2021 | 03:26 AM
Originally Posted by Klxster
Looks good to me..
Yes, I did mention in the video that there are two bolts per cam sprocket, and to do one sprocket at a time, but no, you are correct, I did not go into that each one would need to be rotated multiple times. Hopefully people can figure that out, that's a good point. Thank you for the feedback I really appreciate it.
  #1139
Old 06-26-2021 | 04:53 PM
BRDN's Avatar
Default First post MCM
This is my first post but I've been reading everything on the klx for the last 2 yrs. I did the mcm last week pulled the lid off, installed a #40 pilot and k152 main per instructions. I'm running 13/47 sprokets and a 2 brothers slip on w/ original header. I needed the extra front wheel lift for the sugary sand we have here north of Pensacola.
Im 59 yrs old and 200 lbs. I just got back from an off road ride AND...MAN...WHAT A DIFFERENCE!!!
I'M no wheelie expert but she will power up the front tire off the ground now and really shines offroad. Thanks to all those who went before.
I have one question. If I rev real quick from idle it sounds almost like just a moment of pre-ignition.
I have removed the spring from the acr and am wondering if that's what I hear?
BRDN
  #1140
Old 06-26-2021 | 06:02 PM
I doubt that is the noise. The spring allows the shoes to reach full extension well below idle rpm. Noise could actually be a shade of detonation, try higher octane gas if running 87 It might possibly be the tensioner if still running the OEM, but if so you aren't at a point where it will create a problem. If you are still running the OEM tensioner the tell tale for it going bad is usually rattling around 4000-6000 rpm. But at this point I will assure you if the tensioner is going bad you definitely still have plenty of time before any serious issue could arise. It just doesn't strike me as a problem with that kind of noise.
You might also slightly raise your idle. I know mine is idling a shade higher than most.
Quick Reply: KLX 250 ( 300 ) camshaft mod by Marcelino
