KLR spouting white smoke - Ring replacement?
Sounds like my KLX. Mine always smokes on start-up for a minute and then clears up. I know its the valve seal(s). It has been like that since I owned it, since 2007. It only does it if I let it sit for a week or more without starting the engine.
If it only smells like gas, not likely it's a head gasket, especially if it clears up after warm up. Just wondering has it been hard starting? Can get some smoke just from overly rich starts too.
white smoke is water. either condensation or coolant leak.
When it warms up the aluminum expands and seals off the leak (if there is one)
I have an exhaust leak on my truck at the header and head, for 5 minutes until it gets warm and goes away due to heat expansion.
