Kklx 250s
Old 03-22-2019 | 11:30 PM
Elnene5678's Avatar
Default Kklx 250s
I have a problem with my klx 250s it has spark compression and gas and it wont start
Old 03-23-2019 | 12:00 AM
durielk's Avatar
Push start it!
Old 03-23-2019 | 11:04 AM
Put in new spark plug if the one in there is a bit old. It may spark outside the engine, but inside may fail. I had that with my KLX650, wouldn't start unless bumped off. The plug electrodes were worn enough they wouldn't spark under the compression and all in the cylinder, but would spark like normal outside. Replaced plug and bingo!
Other question - has gas in tank, has gas in carb or has signs of gas mix in cylinder? Obviously if there isn't gas in the tank or not getting to the carb it won't start, but just asking to be sure what you mean by has gas. If your choke and pilot jet are plugged it will not start, You might bump it off, but it may stall at idle. Both signs you have crud in the choke and/or pilot sytem. Needs cleaned, probably best done by some shop or person with an ultrasonic cleaner or a carb washer.
Hope that helps.
Yahua2233
11-29-2016 06:48 AM
mathiaswscott
KX250 & KX250F
01-16-2014 05:39 AM
lukashanson21
KX250 & KX250F
07-01-2012 06:49 PM
EMS_0525
08-05-2010 12:05 PM
msuspartanbigten
06-14-2007 05:44 PM
Quick Reply: Kklx 250s
