KICKER for a KLX
Old 04-18-2006 | 05:22 AM
chainslack's Avatar
Default KICKER for a KLX
Will the kickstart hardware from the 300 likley bolt onto the 250?
Old 04-18-2006 | 05:34 AM
Default RE: KICKER for a KLX
Are you talking about everything it takes including splitting the case? I don't think it's worth it.
Old 04-18-2006 | 12:04 PM
MaverickAus's Avatar
All the part numbers except the kickstart lever are the same
Old 04-19-2006 | 12:40 AM
1iviper's Avatar
ORIGINAL: MaverickAus
thanks,that's good to know.
Old 06-29-2006 | 12:14 AM
Silver_Otter's Avatar
The part number for the complete kick starter ( all Part needed )
99999 99999-0073 KIT.,KICK STARTER 1 (OPTION)
________
apartments for sale in Pattaya
Old 06-29-2006 | 03:31 AM
bryantjt's Avatar
Correct me if I'm wrong but the whole kit is like $600 from Bike Bandit isn't it? I remember looking it up a few weeks back and thought it was ungodly expensive, however there are quite a few parts that have to go in in order for it to work. I was under the impression that everything was in place and you just mounted the kickstarter but that is definitely not the case.
Old 06-29-2006 | 04:13 AM
LOL not the case......Get it case? As in you have to split the case?..........Ok that was really scraping, sorry
Old 06-29-2006 | 06:02 AM
I believe that only the clutch case and clutch have to come off.
The water pup is on that case, so both the water and oil are drained.
The motor should don't have to come out of the frame.
________
Find Headshop
Old 06-29-2006 | 06:21 AM
Bike Bandit
OPTIONAL PARTS
last part is a kit. This is the only part you need.
99999: KIT.,KICK STARTER 5176850-001 $328.32
________
Headshop
Old 08-24-2010 | 07:53 PM
09klx's Avatar
Does this fit the 09?
Quick Reply: KICKER for a KLX
