kick starter part numbers
im after the part numbers for the kick starter kit.
found this can some dubble check. these part number are for the us spec bike, mine is the australian spec, any difference?
sorry about the spacing
1999 klx 250
Description BikeBandit.com
Part Number Quantity Unit Price
120:
BOLT-SOCKET
542023-001 Enter 0-99 $3.20
132:
BOLT-FLANGED-SMALL,6X
US
1543-001 Enter 0-99 $2.65
480:
CIRCLIP 16MM
1878-001 Enter 0-99 $2.92
600:
BALL STEEL 1/4'
[CN]
1880-001 Enter 0-99 $0.26
13061:
BOSS,KICK PEDAL
544740-001 Enter 0-99 $46.96
13064:
LEVER-ASSY-KICK,PEDAL
544817-001 Enter 0-99 $80.32
13066:
SHAFT-KICK
544884-001 Enter 0-99 $68.05
13070:
GUID,KICKSTARTER SPRG
544934-001 Enter 0-99 $6.00
13078:
RATCHET,KL250-D2
USE WITH 13068-032
1885-001 Enter 0-99 $41.65
13206:
GUIDE-KICK
5103-001 Enter 0-99 $6.48
49006:
BOOT
598693-001 Enter 0-99 $4.37
59051:
GEAR-SPUR,IDLE,28T
614434-001 Enter 0-99 $80.48
59051A:
GEAR-SPUR,KICK,29T
614442-001 Enter 0-99 $80.48
92009:
SCREW,6X27
1889-001 Enter 0-99 $5.71
92022:
WASHER THRUST
T = 1.2
622802-001 Enter 0-99 $3.20
92022A:
WASHER,17.3X25X0.5
(KL250DE012137 - )
623041-001 Enter 0-99 $2.92
92022B:
WASHER,PLAIN
I.D.=12.3I
1657-001 Enter 0-99 $0.65
92022C:
WASHER,PLAIN
( LX250DE014834- )
623374-001 Enter 0-99 $5.96
92022D:
WASHER,PLAIN
I.D.=16.3I,0.5
623418-001 Enter 0-99 $3.82
92033:
CIRCLIP,16MM
( - LX250DE014833)
625716-001 Enter 0-99 $3.04
92081:
SPRING KICK PEDAL
[CN]
1891-001 Enter 0-99 $2.92
92081A:
SPRING,RATCHET
1892-001 Enter 0-99 $5.91
92082:
SPRING-KICKSTARTER
[CN]
632883-001 Enter 0-99 $17.50
1999 klx 250
120:
BOLT-SOCKET
132:
US
480:
CIRCLIP 16MM
600:
BALL STEEL 1/4'
[CN]
13061:
BOSS,KICK PEDAL
13064:
13066:
SHAFT-KICK
13070:
13078:
RATCHET,KL250-D2
USE WITH 13068-032
13206:
GUIDE-KICK
49006:
BOOT
59051:
GEAR-SPUR,IDLE,28T
59051A:
GEAR-SPUR,KICK,29T
92009:
SCREW,6X27
92022:
WASHER THRUST
T = 1.2
92022A:
WASHER,17.3X25X0.5
(KL250DE012137 - )
92022B:
WASHER,PLAIN
I.D.=12.3I
92022C:
WASHER,PLAIN
( LX250DE014834- )
92022D:
WASHER,PLAIN
I.D.=16.3I,0.5
92033:
CIRCLIP,16MM
( - LX250DE014833)
92081:
SPRING KICK PEDAL
[CN]
92081A:
SPRING,RATCHET
92082:
SPRING-KICKSTARTER
[CN]
