K&N Crank Case Filter
RE: K&N Crank Case Filter
thanks for the pics.. another mod added to the list come winter time. LOL
i was thinkin about plcement for the filter tho... i might try routing the line back into the airbox through the 2nd snorkle once i hack the airbox lid... dont know if its feasible or not but ill check it out when the time comes...
thanks again.
thanks again.
Oh, another advantage is that if you plan on doing Marty's PCV mod, you could find a PCV that you could use to just replace the coupler with and that would be a quick and simple install if you've already done this one, or you could do them both easily at the same time. Just a thought.
Great Job Brian I will be doing mine soon as it comes in . That should stay dry enough up there
Thanks for the Pics I will post mine when I get them .
scrtch111
05-04-2012 05:13 AM
