Just did MCM
I see.. I used a different kit on my '09 which included just the valve head? and shims. I believe the 2001 kit replaces the entire valve body at the bottom of the fork. Drilling was not a problem, it's pretty soft, just make sure you have the correct size drill bit. If I remember, there was a small indentation where you are supposed to drill, so you are really just completing the hole.
what size bit did you use to drill into the damper?
