Just did MCM
Can also be too low of an idle, it happens with singles where the act of braking quickly can stall the engine. I think it is possibly the quick shut off of the fuel making a lean condition. Either way, in a conversation about turning my 650 into a supermoto I was informed one of the things that should be done is to raise the idle to keep it running under heavy braking and when backing the bike into a turn (like I've ever really done that on pavement). They said run around 2000 rpm for that. I found my 650 did well at around 1200-1300 rpm idle and the 250 right now is at around 1800. I learned on my 500 that sometimes with low idles singles will cough and stall too.
Try turning up your idle a couple hundred rpm.
But even then, the bike still shuts down If I slam on the brakes.
Adjusted the idle and that helped! Thanks y'all
Also, Im going to be rebuilding my suspension this weekend. Springs + Gold Valves.
Anyone have some advice when installing the gold valve cartridges?
What year bike and Gold Valve part #
Racetech instructions were pretty good. Nothing difficult, just take your time, keep things spotless, keep track of your parts and the order they are in. Calipers are handy... required really.
In my limited experience I think Racetech's suggested setup is on the firm side... good for faster riders.
NOTE: You only get one shot at the Racetech website for settings... print your pages!
Took me 2 or 3 tries to get mine where I liked. By the time you pull everything apart for the third time, you can do it with your eyes closed...lol
Its the drilling of the damper that's daunting
I see.. I used a different kit on my '09 which included just the valve head? and shims. I believe the 2001 kit replaces the entire valve body at the bottom of the fork. Drilling was not a problem, it's pretty soft, just make sure you have the correct size drill bit. If I remember, there was a small indentation where you are supposed to drill, so you are really just completing the hole.
