JT Sprocket Gears and Ratios
RE: JT Sprocket Gears and Ratios
Good stuff!
I found this part interesting though.
'Front sprocket available in: 13, 14, 15, 16 teeth'
I don't think you can go above 14 teeth on the front, without modding the cover.
It seems as though a lot of people on the forum are happy running the 13/45 sprocket combo.but is anyone running say 13/49 or anything close to that? If so, How's it working for you? and what chain length are you using?
You can run a 15t sprocket at the front with no modification.
I have 13, 14 & 15 fronts and 42, 47 amd 50 for the rear.
I generally run 14/47 and a 108 link chain. It is pretty close to the front of the adjusters.I can run 13/47 with this chain but not15/47 I doubt you could run 13/49 on a 108, you would need a 110 link chain.
The 50t rear will not allow use of the standard chain guide.
