Jhoffy question thread
Old 06-28-2011, 03:38 AM
GaryC's Avatar
no idea on this one.
Old 06-28-2011, 04:38 AM
redpillar's Avatar
Trail tec makes a few, I have the X2 and the 8" race light and like both.
Old 06-28-2011, 04:46 AM
jhoffy22's Avatar
Which X2 do you have specifically? Any issues wiring the light or getting it to aim properly ahead?
Old 06-28-2011, 05:14 AM
redpillar's Avatar
Here is a link tot he installation of both. I think the X2 I have is the enduro model, it is OK
https://www.kawasakiforums.com/forum...install-34295/
Old 06-28-2011, 05:40 AM
jhoffy22's Avatar
Here is a link tot he installation of both. I think the X2 is the enduro model
There are 3 different X2 head lights. I'm just trying to figure out which one has a sufficient brightness for the road.
Old 06-28-2011, 05:15 PM
jhoffy22's Avatar
Default Bad News
I was just driving down the road accelerating and I heard really funny noise and the engine just cut out. I shifted back to neutral, tried to start it and then engine wouldn't even turn over. The starter wouldn't turn the engine over but sounded like it was trying too. Not sure what to think. Looked at the sight glass and it still has oil in it. Everything was running so smoothly too.
EDIT: I was hitting the side that has the B&B Restoration sticker on it with a rubber mallet and then hit the starter and the engine turned over. It almost sounded as if it had no compression when it was turning over and then it just locked up again while it was turning over.
Old 06-28-2011, 05:38 PM
GaryC's Avatar
you might have siezed it. when it cooled down, it freed up.
Sounds like you need to tear it down and have a look. you can try a compression check first though if you have a guage.
Bummer,,,
could have broken a valve too,,
I wonder if you did the cam mod correctly if it did break a valve.
pull the valve cover and see if everything looks good such as no broken chain and all the cam bolt covers are in place.
  #28
Old 06-28-2011, 05:44 PM
jhoffy22's Avatar
Bummer,,,
I'll tear it down and have a look. I can't test the compression because the starter is not turning over then engine again. I hope the crank isn't seized. I can deal with a broken valve, I'll just reset the cam back to stock because it probably wasn't a good idea to do it with the 351 kit in the first place since I am already dealing with higher compression. I hope it's not something major that runs me a lot of $. I'll be ticked if that piston or sleeve is shot that I just got from BB.
  #29
Old 06-28-2011, 06:00 PM
CousinLarry's Avatar
Damn dude, you have no luck! Back away from the wrench... slowly!
Good luck, let us know of the findings. Hope it's not too bad.
  #30
Old 06-28-2011, 06:08 PM
jhoffy22's Avatar
Not even sure what to look for. Anything obvious to look for? If I rock the bike back and forth letting the clutch out as I rock it and everything turns over smoothly. Gosh I hope its nothing major after I just spent all this money on the bike.
Quick Reply: Jhoffy question thread
