jetting questions
Where are you located. Elevation will make a difference. Lean at sea level may be good at 3k feet, if you are at 5k feet you may need to jet down. You may be fine adding the slip on as long as you do not mess with the airbox or snorkel. A jet kit is nice, dynojet will give you enough jets for most setups and a better needle, as well as instructions on accessing and adjusting the mixture screw.
If you are completely stock at sea level you are more than likely not lean with stock jetting. A jet kit will not hurt as the EPA jetting is not optimal for power/driveablility. If you do a slip-on you may want to back out the mixture screw a bit as it will probably pop on deceleration.
In the old days we just looked at the spark plug on the "2 strokes" to see if it was white---lean
or black-rich----we wanted it to be a brown color.
Also depended on the oil/gas mix ratio------not a concern with the KLX---4 stroke engine
Stashu
Stashu
