Jetting my carb back to stock, need help with fuel screw turns etc.
Old 08-14-2012 | 02:13 PM
WHIP-N-DIP's Avatar
Originally Posted by IDRIDR
Someone said 2 turns out, usually more than stock IMO. But I'd go 1.25 to 1.5. That shouldn't too much for your full throttle. Check to make sure your diaphragm is in correctly. May need a hot soak.
so you thikn the problem is with the mix? i turned it to about 1.1 or somethinglike that... i have a problem getting that flimsy gasket back in, is there a trick to it? i couldnt get it to sit in the groove so i put it on top and poked in the little parts that were sticking out.. but maybe it got wrinkled in there or something..
Old 08-14-2012 | 03:23 PM
lj-rubi's Avatar
Yes, that is definitely a potential problem. You need to soak that diaphragm in HOT! water--like almost boiling--for 5 minutes or longer (until it fits). It will shrink so that it will fit back into the groove at the top of the carb body. If you don't have a good seal there the slide will NOT function.
Old 08-14-2012 | 11:45 PM
Highbeam's Avatar
The DJ kit is cheap. You should have left it alone and bought a new kit for the new bike.
CC_Rider
07-13-2014 02:43 PM
Zen Dude
08-17-2009 01:00 AM
je2000
06-12-2009 01:18 AM
pauley2000
06-20-2008 04:28 PM
tremor38
12-31-2006 05:13 AM
Quick Reply: Jetting my carb back to stock, need help with fuel screw turns etc.
