Jetting KLX250s--Straight from Kawasaki (Technician)
Old 08-04-2018 | 06:25 PM
Wink
Originally Posted by dan888
The "muffler king" is a term of endearment we used to use for Deej. If you want to get on his good side start calling him "muffler king" he really gets a kick out of it.
Take all the jetting advice and use it as a starting point. Your Kawi dealership guy probably is a smart cookie, (or maybe not) , but he probably didn't work on little 250klx's much. The guys on here have found what works for this specific bike, but you will still have variations, because any number of factors affect the jetting. Search jetting on here to find the best starting point, and go from there.
Dan
All hail the Muffler King
Great thread resurrection Montanatown.
All hail the Muffler King!
hahahahaha
Old 08-04-2018 | 10:45 PM
My opinion - go to Pippin's site, he has plenty of tips for the KLX. He did his jetting with Kiehin parts from Kawasaki. It is pretty much the same stuff I read here on other threads and in other places on the internet, learned pre-Dyno Jet kit. My brother and I have followed it and results were good.
If you do Dyno Jet you need to get with KLXter here. Be prepared, he is Trumpish.
Old 08-04-2018 | 11:31 PM
snappster's Avatar
Ha HA!
Old 08-05-2018 | 01:25 AM
Klxster's Avatar
I'm not so bad, once you get to know me...
(Agent Smith - Matrix)
Old 08-05-2018 | 03:37 AM
Montanatown's Avatar
I've been keeping my eye out but klxster has been pretty informative from what I see.
Old 08-05-2018 | 03:48 AM
So I have to say I was not impressed with the ultrasonic cleaner, maybe it needs to be in there more like 8 hours or overnight. I spent a lot of time on each passage and the inside of that carb. It's pretty darn clean.
I just dont forsee that kind of top end loss without a jet difference and I have not been able to get the jet spec from the all ***** out kit to compare to the stock jet.
Old 08-05-2018 | 12:21 PM
When working at the motorcycle dealership, and having cleaned some carbs for myself, we would run a carb or carb set in the cleaner for at least 24 hours. It didn't always work, sometimes taking more time. That was when the cleaning fluid was a bit more potent too.
As for your issue, there is a bit of a trick that might indicate the issue. The "choke" on the bike is an enrichener circuit, adds a bit of fuel. When you run up to the flat spot reach down and pull the choke **** out. If the engine pulls a bit stronger, not much, but likely slightly noticeable, it is running lean. Go up a jet size or two and see what happens. If it stays the same or drops a bit, it's likely a bit too rich. I used this method when I was encountering a mid range stutter at around 6000 rpm. Pulling the choke smoothed it out almost completely.
  #28
Old 09-04-2018 | 01:45 PM
It revs perfect when not in gear so I'd have to try the choke trick on the road and see if that made any difference. I have adjusted the air mixture screw and it has help the bottom end a bit but top end is taped out at 6000 in gear and stuffers from around 5500 rpm. I'd think to lean but haven't been able to confirm yet. But if I clutch and give it throttle it will run up with no hesitation or studder.
  #29
Old 09-04-2018 | 03:16 PM
Definitely sounds lean. Do the choke trick. Unless jetting has been changed it will be lean. In Keihin parts for altitudes over around 3000 ft most run a 125 main and the N1TC needle not sure which groove, check Pippin's site, he was up around 3000 ft. For us around sea level to around 3000 run the 128 main, N1TC needle in the 2nd groove from the top, that's what myself and others run.
If using Dyno Jet, check with KLXter, he knows their stuff.
  #30
Old 09-05-2018 | 02:01 AM
Klxster's Avatar
It would seem you still have a fault within the carb. Getting a "gunked out" CVK back in "like new" operation requires a good bit of knowledge of the componentry within..
E.G, - How did you manage to clean (and make like new) the pilot jet, the emulsion tube, pilot air jet, main air jet, the casting that is the emulsion tube "housing"...?
Could the needle jet be upside down..?
Did you test the slide operation, after reassembly, to verify proper operation.. ?
Air/vacuum leaks..? Bowl vent line routing,,?
My troubleshooting thread might help - https://www.kawasakiforums.com/forum...s-fixes-43146/
Quick Reply: Jetting KLX250s--Straight from Kawasaki (Technician)
