Jetting changes with 300cc kit?
Old 03-19-2009 | 04:08 PM
TrailCruiser's Avatar
Default Jetting changes with 300cc kit?
I'm about to install the Kawasaki 300cc cylinder/piston on my '06 KLX250S. I have the jetting just about tweaked perfectly for it as a 250, will the displacement increase cause changes to be needed?
Seems like it wouldn't, the engine will just be pulling a bit more air through the carb but it seems logical that the air/fuel ratio should stay the same.
Thoughts/experience?
Old 03-19-2009 | 11:08 PM
ol guy's Avatar
Mine was running a little leaner than I like with the 128 so I went to a 132. I'm at about 500 feet above sea level, stock pilot, open air box, and a k&n, with a two bros slip on.
Old 03-20-2009 | 12:23 AM
buffalony's Avatar
Get the Dynojet kit for the klx300. It has everything you need and instructions.
I did the 300 kit back in January. I actually just got a chance to ride it a couple days ago. it is not a rip roaring beast, but the changes were noticable. I feel like I could now actually pull a wheelie without beating the clutch in first for sure, maybe second. A wheelie in thrid would take some gear changes or serious flogging of the clutch. You will be happy with the outcome
IchWarriorMkII
10-13-2006 04:07 PM
neilaction
10-11-2006 05:28 PM
ntloser
09-04-2006 09:37 PM
dazjr
05-09-2006 08:59 PM
