Jets vs carb replacement
Old 08-19-2015 | 02:02 PM
taxonomy's Avatar
Originally Posted by Rock Hugger
I'm running a 13/49, while its great on there trails where I do most of my riding, it is to low for much highway riding at highway speeds. It also did not make it a wheelie machine.
In first and second a twist is all it takes to lift the front. It wont do it when you're sitting on the tank but it'll do it pretty easy otherwise.
I have a 14/48 combo and I think it's really good. It will go on the highway but I wouldn't go touring on it. My old commute included 10 highway miles and that was all I wanted.
For a woods bike that you need to ride to trails I think my current setup is pretty ideal.
  #62
Old 08-20-2015 | 06:25 AM
Rock Hugger's Avatar
Originally Posted by klx-vn
Thanks Rock Hugger for all the updates. Simple question: When you whack the throttle off idle now does it bring a smile to your face or does it fall somewhere below initial expectations?
It does feel like a different bike, I like it!!
I rode it about 20 miles on the road today. I think I need to richen the needle. Cruising with a consistent throttle input (about 1/3 throttle) it has an occasional hiccup. If I'm accelerating or WOT it doesn't do it.
  #63
Old 08-20-2015 | 07:08 AM
The other thing I discovered today is that the vent hose from the float bowl weeps fuel while it sits, its not much but it does leave a small damp spot on the ground below. I'll have to check the float level and make sure the float needle is closing all the way. I shut off the petcock and let the bike run run a minute before shutting it off and its not weeping now.
jamesecox
05-16-2012 01:37 AM
spinalcracker
02-04-2011 08:29 PM
dillon
Ninja 250R
07-18-2008 05:36 AM
mole
08-07-2007 07:55 PM
Notstock
01-05-2006 05:07 AM
Quick Reply: Jets vs carb replacement
