Which jet kit is best? (general 250S jetting questions)
Old 08-29-2008, 01:07 AM
WestOzKLX's Avatar
Originally Posted by JasonFMX
oh, and if you go to the kawasaki website they have parts diagrams and for the carbs on the 06 at least it says they have a 118 main and they give the part number, and they also give the part number for the 116 main
You can forget about those jet sizes altogether.
Start with a #128 or #132. Corrected for altitude.
  #52
Old 08-29-2008, 01:09 AM
WestOzKLX's Avatar
Originally Posted by JRock420
I rejetted mine to a 124 cuase I still dont have an exhaust yet and Its running 110% better than it did with the stock jet
and i was under the impression that my stock jet was the 118,, Ill check it when I get home,, thanks for the heads up Magoo
So you took the main out and didn't look to see what size it was?
Mine was a #132. Sorry about the width!
  #53
Old 08-29-2008, 01:53 AM
WNCSte's Avatar
Default Now I'm confused
So WestOZ, Your stock main jet was a 132, and you replaced it with what?
Or you didn't replace it?
  #54
Old 08-29-2008, 01:16 PM
No West Oz,, I sure didnt lol... hey im learning,, but when I get a chance Im goin to look at it and see what it was...
  #55
Old 08-30-2008, 01:40 AM
WestOzKLX's Avatar
I've gone #138. . She loves WOT.
  #56
Old 08-30-2008, 04:19 AM
sharkbyte48's Avatar
This is true if you stick with the #35 pilot you can keep turning the screw out as far as you want and it doesnt richen up and its harder to start with #35. change to a #40 and its better, better low end response and better starting, you'll be much happier KA92064-1108
  #57
Old 08-30-2008, 04:34 AM
WestOzKLX's Avatar
I've had the #40 in for a while. Runs a tad rich off idle to 1/4 throttle. Going down to a #38 (KLR650.) Worth a try.
  #58
Old 08-31-2008, 12:25 AM
Yeah i though the same thing, i'm thinking of moving my neede up to the 3rd position, cause the power doesnt kick in until about 6krpm
  #59
Old 08-31-2008, 12:43 AM
WestOzKLX's Avatar
I'm running the stock AUS needle (N1RX) raised 1.5 mm. It's about right.
Just gotta tweak out the richness down low.
  #60
Old 09-01-2008, 01:13 PM
Ok guys just checked it out.. My stock Main Jet was a 118 lol
Quick Reply: Which jet kit is best? (general 250S jetting questions)
