It's Jetting time again. "Advice please"
Old 06-26-2012 | 09:28 PM
klx4me's Avatar
Originally Posted by ACOLE
The reason I went for the 132 is that the Australian model comes standard with it. It only coughs occasionally.
Dynojet & Keihin jet nomenclature are different. I have seen a table that shows a DJ132 = Keihin 142 which is huge for your set up hence the flatspot on acceleration. BTW DJ128 = Keihin 138 which is what I run. The table I'm referring to is on a site called jets-r-us
Old 06-26-2012 | 10:49 PM
ACOLE's Avatar
Thanks for that. Really good info. http://www.jetsrus.com/FAQs/FAQ_miku...ihin_sizes.htm
This is what distracted me. You can see the KW difference between the AU and the others and the same for the main jet. New Zealand gets the CA Spec. It's from the 09 KLX250s Manual.
I never realised the DJ jets were different to the Keihin.
Again thanks, looks like I'll be back on the tools this morning.
Old 06-27-2012 | 12:32 AM
BigSky KLX's Avatar
Remember, dyno jets and kawi jets are not the same.
A 132 dyno jet is way bigger than a 132 kawi jet. I used to have a conversion sheet laying around ( if you search I am sure you can find it ).
A 132 kawi ( or keihan ) jet is equivalent to a about a 124 dyno jet.
-EDIT Dammit, I was a little late
Old 06-27-2012 | 01:04 AM
ACOLE's Avatar
Yes, just got a reply email from Dynojet Research in Las Vegas. Hole size is the same but the taper is what is different.
Old 06-27-2012 | 05:07 AM
ahnh666's Avatar
have about 10,000 miles nowl...ran the dj132 for a long time...over 5,000 miles now...
Old 06-27-2012 | 10:24 AM
YAY.... another jetting thread with the same info that has been covered a million times over..... LOL.
Plus what works for one person may not work for you. So you WILL have to play with your jetting a bit. If you would rather not. Take it to a shop. I like working on my bikes.
Old 06-27-2012 | 10:36 AM
ACOLE's Avatar
Yep I'm done. Went back to the dj128 today. Haven't ridden her with the 128 but at least I know what the 132 feels like. Thanks for your input everyone. Over & out from NZ.
Old 06-27-2012 | 10:41 AM
ACOLE's Avatar
P.S Here's the reply from Dynojet for anyone interested.
"The Dynojet main jets and the Keihin main jets are sized the same, we both use hole size in mm. a DJ128 has a 1.28mm hole same as the Keihin 128 main jet. The main difference is the tapper leading to and from the hole. The tip of the needles has a large affect on the main jet size. I have had customers in Australia use the Stage 2 setting with the snorkel removed with good results.
Let me know if I can be of any further assistance."
Thank You!
Michael Cory
Research & Development
Old 06-29-2012 | 07:40 AM
ACOLE's Avatar
P.S.S.
Bike is awesome mid-high, not so great down low. Banged off another email to Dynojet who came back suggesting lifting the needle to 4th notch. Did that today & did a 30 klm gravel run. Wow different bike. Heapes more power down low, really happy with results.
Old 06-29-2012 | 09:47 AM
P.S.S.
Bike is awesome mid-high not so great down low. Banged off another email to Dynojet who came back suggesting lifting the needle to 4th notch. Did that today & did a 30 klm gravel run. Wow different bike. Heapes more power down low, really happy with results.
Awesome. Glad you got it worked out. Jetting makes a huge difference.
cpr1
05-30-2011 04:47 PM
cpr1
05-30-2011 04:44 PM
work
02-06-2011 02:06 PM
zzrotceh
ZZR 600
02-01-2011 06:23 PM
davehayward1
09-20-2010 07:28 AM
Quick Reply: It's Jetting time again. "Advice please"
