It's Jetting time again. "Advice please"
Bike: 09 KLXs250.
Has Two Bros slip on and uni-filter.
Am fitting the stage two Dyno Jet Kit.
Dynojet recommends needle on third groove from top, 128 main, Mixture screw 3 turns out and fit slide spring supplied.
I live pretty much at sea level and don't ride anything higher than around 800 feet.
Question 1:Can i run the 132 main that also came in the kit and should i be replacing the Pilot jet as well. If so what size.
Question 2: Do I install all three washers above the e-clip.
I'm going to finish with the KDX snorkel.
Waiting patiently.
Waiting patiently.
Bike: 09 KLXs250.
Waiting patiently.
Waiting patiently.
i'm running with the dj132 at sea level..no change to pilot jet....k&n and kdx snorkel...hmf exhaust...3 out to start and slowly turned the screw back in millimeters at a time...just adjusting by sound and feel....i think my a/f screw is about 2.75 turns out...also have the needle in the 3rd groove....idles and runs perfectly...i haven't had any problems going up and over mountains either....
Wow what a different bike.
Went with the 132 main and 2&3/4 turns on the A/F screw.
Coughs occasionally under hard acceleration in 3rd and 4th usually just the once.
Am using the KDX snorkel a s I found the noise running without a bit annoying.
Anyone have any thoughts on the cough?
Maybe three turns out on the A/F?
i don't have any "cough" at acceleration....never experienced this...but, i ran my klx with an open air box at the time.....closed up the airbox and added a kdx snorkel after installing the k&n due to excessive noise and vibration...
The reason I went for the 132 is that the Australian model comes standard with it. It only coughs occasionally.
