Interchangeable triple clamps?
Old 06-21-2018, 02:08 AM
Don Tripas's Avatar
Default Interchangeable triple clamps?
Looking in to some purchasing some new triple clamps for my 09 KLX250s.
ive read that some kx forks will fit on the klx?
will the KX triple clamp fit on the KLX w stock forks?
thanks
Old 06-21-2018, 03:56 AM
Brewster's Avatar
Early to mid 1990"s KX triples will fit the 43mm forks. Forks got larger diameters after that and the steering stem diameter changed.
Ride on
Brewster
Old 06-21-2018, 04:13 PM
Don Tripas's Avatar
Ride on
Brewster
Right on. Im thinking of possibly swapping some KX forks to my KLX250 along with the KX Triple Clamps. Would something like this work or would some custom fabrication need to be involved.
Thanks again
Old 06-21-2018, 07:40 PM
Brewster's Avatar
Fortunately, the PlanetKLX website is archived. Here's the information on the fork swap:
https://web.archive.org/web/20170406...-forkswap.html
One thing to check is the length of your stock forks compared to the KX forks. Different length spring spacers may be needed.
Ride on
Brewster
Old 06-21-2018, 08:10 PM
Don Tripas's Avatar
Ride on
Brewster
Thanks man. I appreciate it.
Old 06-22-2018, 02:09 PM
lj-rubi's Avatar
I have a complete set of OEM forks and triple clamps from an '09 bike. PM me if you are interested, thanks.
Old 07-26-2018, 08:25 PM
Don Tripas's Avatar
Ride on
Brewster
Hey dude,
I found out I need to change my key ignition as its faulty and not delivering power. An OEM ignition new costs roughly $100 for 09 KLX250s. Even then I would have to tap the bolts to remove the bad one on my bike. I revisited this thread and remembered you said some early to mid 90's KX triple clamps will fit the 43mm forks on the KLX.
Im finding some 92 and 93 triple clamps on ebay for a much cheaper price than 09-14 klx triple clamps. If go with the KX triple clamps, im wondering where the key switch would go. Do you have any suggestions?
Thanks ahead of time!
Old 07-27-2018, 12:42 AM
Brewster's Avatar
Sorry, but I have a KLX300 = no ignition switch.
Ride on
Brewster
Old 07-27-2018, 03:24 AM
durielk's Avatar
.... in the trash?
Old 07-27-2018, 02:47 PM
Don Tripas's Avatar
Originally Posted by durielk
.... in the trash?
que esta en la basura?
Quick Reply: Interchangeable triple clamps?
