Installing Edge Lighting
Hello, question for thoses who have installed "edge tail light" on their klx's, I tore my old one off and before i cut the wires to mate up, did any of you solder your wires from harness to light ? Im thinking if i just crimp them like with what comes with the installation kit ,it would prone to water and other elements? wires seen very small gauge, pls give me your thoughts, thanks, Chas.
+ another for crimping, heat shrink tubing over that, and electrical tape on each end. No problems. I also zip tied it tup to the sub frame keep it from dangling & out of the way of mud and debris.
This is actually the first mod I have done to mine and I just did it last night. I used the supplied connectors plus I soldered the wires to the connectors. Be careful not to use too hot of an iron as you will melt the plastic on the wires. I just went with electrical tape versus heat shrink.
VB
VB
I cut the stock harness after the plug and soldered it onto the Edge light loom.
Easy enough to solder it back to the original should I ever need it.
Paul
________
Justin bieber fan
Paul
________
Justin bieber fan
VB
VB
I trashed the connectors in the kit and crimped on better connectors. Used the liquid electrical tape to seal. I love that liquid Etape as you can stuff your crimped connections with it and it dries into hard rubber without shrinking. The original factory connections weren't exactly sealed either so don't sweat this too much.
I agree, wire size seems small but factory bulb is only like 10 watts.
