Installed a Kickstarter on my '07 KLX
Old 02-23-2020, 02:17 PM
I may have already missed it, but why no e-start?
I've never considered the kick start because I nearly always ride with one to three other riders and we can bump start any bike if the battery is dead or other problems. Only time I ride alone would be on decent roads, no rough stuff, places where if something happened I would not be stranded alone. Just sayin' my alternate starting method has never failed... a push and a bump.
  #32
Old 02-23-2020, 05:44 PM
durielk's Avatar
I would think a FI engine would be harder to start, but I'm not an expert.
To rotate the engine in gear, use 2nd ...or 3rd.
I try to bump start my 650 single sometimes, it usually just slides the rear wheel in 2nd.
  #33
Old 02-23-2020, 06:42 PM
Klxster's Avatar
If your bike has started with the kick starter, then it has to be a matter of finding the correct procedure - which may be (is likely) different on a EFI bike from a carb bike (due to EFI triggering, battery voltage level, ect)
MCM is a procedure that retimes both cams - for significantly more power below 6500 rpm. It can be done on ALL KLX250's...
  #34
Old 02-23-2020, 08:57 PM
That's where the friend(s) come in. I can be on the bike and drop my butt on the seat to get it to roll and fire up.
  #35
Old 02-23-2020, 10:40 PM
durielk's Avatar
I don't know, it is very difficult on the 650. I think I did it once, but can't remember when as all the times I couldn't, I remember that usually happens!!
Doesn't matter friends, neighbors, the guy standing there... very hard.
  #36
Old 02-23-2020, 11:19 PM
Rene Tan's Avatar
The housing/bearing point for the gear between the starter motor and crank cracked. Hence no electric start. It was still a 331 then. When it would not kick start, I decided to put everything back to OEM (250), including the ECU.
I have read something about altering the cam timing, especially on the inlet side. Something about moving the mounting points of the cam/gear and rotating the cam by one tooth to achieve a 10° difference. Taking the max intake opening from 110° after TDC to 100° after TDC. Is this MCM you were referring to? I will play with this idea once I can reliably start the KLX.
Point taken about technique. I will try to reference the piston position with the valve openings. The difference in effort/feel is much more pronounced.
  #37
Old 02-24-2020, 01:36 AM
My co-rider/friend and I went out for a day when my 650 was not starting well. Had to bump it off every time. Some times I parked in such a fashion where I could be going down hill a bit. Like I say, I'd rock it back against compression to give the engine a bit of spin before it hit compression again.
  #38
Old 02-24-2020, 01:40 AM
It is linked in my signature to a Google document with the specific instructions with pictures, Klxster has a pdf with a good illustration too. There is a sticky in the KLX250 thread for the MCM, but the pictures are no longer there. It describes what is being done. My document is the hands-on mechanical part gleaned from the thread to make it clear without any discussion in it. Not hard and does add mid range power without killing off the top end.
  #39
Old 02-24-2020, 02:02 AM
Klxster's Avatar
K l x s t e r !!!!!!!!!!!!!!!!
It's with an "s" .. Look between your "A" and your "D" keys, you'll see it !
Oh nevermind.. I give up... You win KLX876..
  #40
Old 02-24-2020, 03:40 PM
Fixed, just used to doing KLX and missed. First time i believe, but not sure. Apologies.
Quick Reply: Installed a Kickstarter on my '07 KLX
