inner tubes
Old 04-09-2010 | 07:55 PM
roadglider's Avatar
I have had to shove a 21 inch tube in the rear tire before, and I've changed plenty of flats on the trail. The 21" tubes in the rear tire work OK in the dirt but their a little weird feeling, especially cornering, once you get back out on the road. But it's way better than running flat. Definiately get the HD tubes. I put a rear rim lock on my 09 and yes it does throw the tire out of balance. Since I mainly ride off road with this bike I haven't put on any balancing weights but I probably should.
Old 04-09-2010 | 08:13 PM
armycopter's Avatar
I threw rim locks on both wheels. I had to have them balanced as it was just too awful riding without some sort of counterbalance. In hindsight I wish I hadn't put one on the front but I'm glad I did the back.
Old 04-10-2010 | 08:55 AM
MaverickAus's Avatar
Apart from all the advice on this thread the only other thing I can add is leave the valve nut loose under the cap. I ripped 2 tubes (inc a hd one) before learning this trick. Haven't had a problem since. 1 rim lock on the back and balance it (if riding over 50mph often), I don't need one on the front but it depends on what you are doing with the bike.
klx-vn
06-12-2014 12:50 AM
mouka
08-04-2009 02:22 AM
Worlok14
05-08-2008 03:37 PM
joboy77
07-14-2007 04:16 AM
unclean title
04-12-2007 09:03 PM
