info on 13th sprocket
Old 02-26-2008 | 12:36 AM
Flood_33's Avatar
Default info on 13th sprocket
Where did you folks order your 13tooth sprocket at? Could someone give me a link so that i may also order me up one? Thanx in advance..
Old 02-26-2008 | 12:48 AM
neanderthaler's Avatar
Default RE: info on 13th sprocket
ordered mine from cycle gear using the western powersports offroad catalog. brand is PBI sprockets. i've been using a sunstar 13t sprocket in the front but just received an e-mail from sunstar saying that they incorrectly listed this as a sprocket for our bike. oh well, its been working fine for me thus far. hopefully tommorrow will bring my 13t front, 47t rear PBI sprockets and new RK chain.
Old 02-26-2008 | 01:32 AM
Davebert's Avatar
ORIGINAL: neanderthaler
What was the part number of the Sunstar sprocket you used that they said was incorrect?
Thanks,
db
Old 02-26-2008 | 01:40 AM
Flood_33's Avatar
I did some looking ,inkawikathys photobucket and found a part number for moose racing sprocket, 1212-0198. guess if i just look i can find what i am looking for...
Old 02-26-2008 | 01:42 AM
Davebert's Avatar
I put this Sunstar on our bike. I gave the local dealer the number and had him order it. It fit perfect.
Part number is Sunstar 34213
db
Old 02-28-2008 | 11:29 PM
that's the one. my dealer ordered it for me also. i don't know why sunstar said it was incorrect, because mine also was a perfect fit, and has run with no problems (that i know of) for four or five months. this time i went in to the dealer after doing some research here and told them what i wanted to order with part numbers in hand. this seemed to work better than letting someone else order for me. also, since posting above, i revised my sprocket order to PBI 13 front/45 rear. i think 13/47 is a little drastic. i will find out next week when the parts come in, and i get a chance to ride.
Old 02-29-2008 | 12:23 AM
Flood_33's Avatar
Yes double thanks guys i ordered my sunstar and its in now i just gotta go pick it up, i'll hopefully get some pics of the carnage *putting in on * and some good riding with it on
Regards,
Old 02-29-2008 | 12:30 AM
IaGy's Avatar
this is the sprocket that you need. It has the all important shoulder that goes toward the engine when mounting. When you go to break the nut loose on the shaft, quickly jerk it and it will break loose. Do not slowly apply pressure as this does not work. A quick jerk and it comes right off.
http://denniskirk.com/jsp/product_ca...p;mmyId=500203
Old 02-29-2008 | 12:43 AM
klx250s_rider's Avatar
Yep a real good hard jerk! I just went to the Kawi-Honda dealer and got a Moose 13T for a Honda XR650L which is a perfect fit for the KLX. Same one we put on KawiKathy's bike.
Old 02-29-2008 | 12:50 AM
Flood_33's Avatar
The guy at the parts place said the sunstar number you guys gave me was correct, ZOMG you guys freaking me out !!!![sm=dontgetit.gif]
jeffzx9
10-23-2013 05:22 PM
RIKLX250S
11-10-2007 12:35 AM
Marty
KLR650
12-07-2006 11:44 AM
racedoll
08-05-2006 05:14 AM
Quick Reply: info on 13th sprocket
