Ims+tm36+....
Ims+tm36+....
Hi, finally putting everything back. Final setup is 351 kit + TM36 + FMF powercore. I have few questions at the moment:
1. IN/EX marks are not aligning perfectly with T-mark whatever I do. They are about half teeth behind. Bike has 30k and chain could be extended. Is it problem?
2. How throttle lines should be routed below IMS tank? IMS tank use all space above the head and lines going across (from right to left) do not allow to it sit properly.
Anyway I fired it and it started fine. Seems to be getting hot very quickly or it is my imagination.....
