IMS Plastic tank shroud bolt insert spinning in tank......???? Now what...????
Ok, So some of you may have seen my thread about my electrical issue. When I went to remove my 3 gal IMS plastic tank, the one bolt on bottom side right is tight into the threads on the bronze or brass threaded bolt insert. When trying to remove that bolt, the metal insert is spinning in the plastic, so I can't get that bolt out in order to remove my tank. I know this has been a problem for some of you. I do use greese or Anti-Seize on them, but this one isn't coming out. I must have over tightened it. Anyway, has anyone had this happen, and do you have any ideas on how to remove this bolt without cutting that tab on my frame? I removed my coil, but it was a pain in the *** getting to it with tank still on the bike. I will need to remove the tank soon anyway soon when I check my valve clearance. Also maybe a BB 351 kit too. I'm wondering if I just spin the **** out of it with my air wrench to really loosen it up, then pry and pop it out? But I can't chance having a leak. I don't think this will cause a leak, but to late if it does. Thats $270 down the drain. Any ideas? What did you do???
Thank You, I appreciate any ideas or help with this....
I think spinning the **** out if it will heat up the plastic and possibly let the insert come out of the tank completely. Maybe not a bad option, but can you get a screwdriver between the frame tab and the insert to give it a little resistance to spinning?
Spin the bolt until the insert comes out or use pliers on the bolt to pull the insert out. Use pliers to hold the insert and unscrew the bolt. Use epoxy and glue the insert back in place. Let the glue set and harden for the prescribed time on the instructions. Assemble as normal.
Thanks guys. I did try to wedge an ahl point in there, but can't get it to hold. I'll keep trying and at worse case, I'll just pull it out. It's just so tight right there. If you have the bike, you know what I mean. I'll keep ya posted on how I make out.
Done this on my KLX250 Acerbis and KDX220 stock tanks with mediocre results on epoxy holding the retainer back in the plastic. The right epoxy would probably improve things.
I don't think a heat gun would be any better. Be smart about it. Drain the tank and let it vent for a while, leave the cap off, keep an extinguisher handy.
I've had good results with jb weld for just about everything I ever used it on. It might also help to put a little tooth on the parts being epoxied also. A round insert in a round hole being the worst possible case. If the plastic is thick enough around the insert, file a couple grooves in it.
Oh and if you do the heat gun thing, put your go-pro on a tripod for the rest of us.
