if your scared to do the valve adjustment yourself...
Old 04-07-2010, 09:49 PM
Now, now .... young man. I got a bit of history with deej and can give him a bit of grief.....but you ... I think not.
Yeah, watch your step PE. FM and Deej are practically brothers.
Old 04-07-2010, 11:05 PM
redpillar's Avatar
Hey finger did you write that stuff yourself?
Old 04-08-2010, 01:33 AM
Ezekiel 25:17 http://www.youtube.com/watch?v=UmvnXKRfdb8
One bad M-Fer
Old 04-08-2010, 01:38 PM
I can't believe you have not seen Pulp Fiction ..... as disturbing as parts of that flick are, it is still a must see movie, rent it.
Old 04-08-2010, 02:15 PM
Putt putt? Uhhhh if 7-8 grand on the tach is putting around then ok??? You try lugging around a 250 lb guy LOL
Old 04-26-2010, 09:16 PM
maninthesea's Avatar
did my valves this weekend. The tip to use a magnet to remove the buckets was good. I also used the magnet to place the shims. Just put the shim on the end of the magnet set it in the middle of the valve & slide the magnet to the side and the shim is perfectly placed,
Old 04-27-2010, 02:01 AM
RaceGass's Avatar
I always thought that the cam chain would come off the crank if you loosened it up.... doing 2 stroke topends for years makes you plex unneccessarily about topends with all these extra parts.
Old 04-27-2010, 09:20 AM
I zip tied the chain to the cams in two places. It did not seem like there was enough slack to let it come off the crank as the tensioner guide pushes in and take up the slack even with the tensioner removed. To get the cams back in place without feeling like I was not scrapeing anything I pushed in the tensioner with a plastic rod so I dont think there is too much chance of chain comeing off and slipping a tooth.
evil636
03-10-2008 03:11 AM
EMS_0525
10-11-2006 10:58 PM
RubberxSidexDown
Ninja 500R
17
10-08-2006 10:51 AM
ntence
06-03-2005 04:26 PM
ntence
05-14-2005 12:11 AM
Quick Reply: if your scared to do the valve adjustment yourself...
