Idle speed after re-jet...
Old 12-11-2006 | 05:55 AM
tennisman's Avatar
Default Idle speed after re-jet...
What idle speed (rpm) should I be running? After re-jetting, I think I'm idling a bit higher than before (2200 rpm).
Thanx, Lance
Old 12-11-2006 | 06:05 AM
klxstiffler's Avatar
Default RE: Idle speed after re-jet...
1300-1500
Old 12-11-2006 | 07:22 AM
jeepphamilee's Avatar
ORIGINAL: klxstiffler
1300-1500
+1
Old 12-11-2006 | 01:56 PM
just adjust it with the little **** on the side... it will idle down, my bike idles real low... 1300 or so... like deej says... Sounds like a helicopter... at least with the big gun and no quiet insert...
Old 12-11-2006 | 07:41 PM
YYY.GUY's Avatar
Don't forget to "blip" the throttle after each turn of the idle adjustment. Otherwise the idle won't change and you'll keep turning the adjuster, then when you do twist the throttle, it may die because it was too low.
Ramitt
07-15-2015 11:18 PM
Richard Avatar
03-26-2014 07:34 PM
Sharan
11-25-2012 09:36 PM
ttakata73
08-27-2010 03:29 PM
50 Slider
06-10-2006 07:13 AM
Quick Reply: Idle speed after re-jet...
