I screwed up
Old 09-09-2015 | 01:43 AM
RANGERRANDY90650's Avatar
Default I screwed up
So, long story short, I ran my bike with no oil and the tens seized. It started right back up after I added oil but needless to say there are noises. It will shift through all the gears but if I try to push start it the tire won't move. Anyway, just looking for advice. Tear it apart or take it and pay the piper or just try and find a new engine/ trans?
Anyone have a 2009 engine/ trans combo to sell?
Old 09-09-2015 | 02:02 AM
ol'klx-er's Avatar
How long did you run it dry? A complete unit might be the way to go. There have been a couple of KLXs being parted out recently.
It would help to show your location, engine/trans shipping could be pricey.
Old 09-09-2015 | 10:49 AM
2wheeler's Avatar
I have to ask this. How does 1 run a m/c w/o any oil in it? Did you change oil and get side tracked w/o filling it, then a few days later ride it?...............S/it happens.
Old 09-09-2015 | 02:50 PM
Michaelb2's Avatar
someone is parting out a 2009 on this board.
Old 09-09-2015 | 05:23 PM
Brieninsac's Avatar
You gotta check that oil at least once a month.
Old 09-10-2015 | 03:11 AM
Default Absent minded
When I left Germany I had to drain the oil. When I got back to the states it was almost a year before I had the chance to ride because of a deployment. It wasn't till after I started it and ruined it that I remembered I had drained the oil. So stupid of me.
Old 09-10-2015 | 06:48 AM
Rock Hugger's Avatar
Find another engine. As stated, someone is parting out a bike on here.
Old 09-10-2015 | 07:08 PM
wildcard's Avatar
Where are you located ? From you user name i assume CA ?
shipping a complete engine will likely be quite costly so i would check you local craigslist and see what might be close on ebay. i would offer my 331 up but shipping from MO to CA would prpbably cost the same as the motor.
Old 09-10-2015 | 08:58 PM
My guess would be the cam bearing surface would be the first to have serious damage from seizure, the cylinder/piston next. The ball and roller bearings probably would tame more time since there would be residual oil there. Consider a two stroke runs on that bit of oil in the gas using ball and roller bearings.
Pull the valve cover and see how the cam surfaces are.
Old 09-11-2015 | 05:39 PM
I want to pull the whole thing out and just start tearing it apart. But I just dont have the time to do it. I was thinking abour pulling it and taking it to a mechanic to tear apart.
Quick Reply: I screwed up
