Was I running rich?
Old 03-22-2012, 01:19 AM
2007KLX250S's Avatar
Default Was I running rich?
So I finally got around to buying a pipe and jet kit. I took the bike apart today and jumped into the carb for the first time. Looks like i was running a #132 main jet this whole time. When I bought it last year the PO said he installed a K&N air filter with air box lid removed but never mentioned jetting it. The bike always seemed to run strong...
I think I'm gonna go with the #128 main since thats what dynojet suggests and I've seen that size around here quite a bit
Any comments? suggestions?
Old 03-22-2012, 02:03 AM
Brieninsac's Avatar
Sounds like the previous owner didn't know what he was doing.
Old 03-22-2012, 02:35 AM
2veedubs's Avatar
Or maybe he did, as the bike always seemed to run good. The 132 was probably not a DJ132. My 250 would run with the DJ132 just smelled really rich out the back end. DJ128 works great with aftermarket pipe. Even without a pipe no airbox lid and a K&N will require more fuel.
Old 03-22-2012, 02:52 AM
Looks like he had trouble with the diaphragm as well because he used sealant to keep it seated.... not lookin good so far
Old 03-22-2012, 05:27 AM
WestOzKLX's Avatar
Stock KLX250 (AUS spec) comes with #132 main jet from the factory.
Old 03-22-2012, 09:14 AM
Dont forget Kawasaki #132 is different than dynojet #132....
Old 03-22-2012, 12:26 PM
linkin5's Avatar
You said the bike ran well, well the jetting must have been close as the first sign of a jetting issue is a bike that doeen't run well.
Old 03-22-2012, 12:28 PM
Bike can run well and still be really rich.... I thought my bike ran good before i rejetted it for CO. Then i didnt touch the jetting when i came back and took it for a ride and it ran better. I think i had it a bit too rich and when i tweaked it, i got it spot on.
Old 03-22-2012, 02:31 PM
rgoers's Avatar
I read as much info as I could find, before re-jetting mine. One trick I ran across was to drop the diaphragm in a cup of HOT water as soon as you remove it, to keep it from expanding. Worked for me.
I'd be worried if I found sealant in there... might be a good idea to clean the surfaces and just install a new diaphragm. You don't know if the PO drilled it or not... My '09 DynoJet kit came with a new spring, and did NOT tell me to drill the hole in the diaphragm.
Old 03-22-2012, 04:06 PM
linkin5's Avatar
Anytime I have a bike that runs well at all rpms and I want badly to have a problem to fix jetting would be thet last thing to come to mind for me. My KLX is a little fat on either the needle or the main but runs and pulls as good as I could ever expect it to so I'm not real concerned over it and have lost no sleep over the issue.
Quick Reply: Was I running rich?
