I over-torqued a screw and it broke-in a bad spot
Old 10-16-2008 | 05:48 AM
neilaction's Avatar
. Hasn't failed me yet and I've never had to resort to a Helicoil. .
Yep, spot on Gavin, your method is the method I have also used and it works well if a bit of the bolt is exposed.
Helicoils are indeed a last resort and will only be needed should you stuff it up. This is normally when trying to make it easier by not removing the side cover. In the end you make it worse.
Old 10-16-2008 | 06:34 AM
MaverickAus's Avatar
Leave it alone until you have to take off the cover. Deal with it then by taking the cover off and use vice grips to grab hold of the end of the bolt and undo it.
Old 10-16-2008 | 03:11 PM
If I remember, the bolt is only like 1/4 inch across, and if its broke off inside a ways, there is no way you can center punch it. Just take off the cover.
CousinLarry
12-22-2010 02:33 AM
mfcordova2008
11-17-2009 12:49 AM
KLX250dualsporter
07-16-2007 09:55 PM
kali_ninja500
03-27-2007 04:40 PM
Quick Reply: I over-torqued a screw and it broke-in a bad spot
