I need some help! Broken Bolt!
Hello guys.
I did something stupid. I broke a bolt on my KLX.
There are three bolts keeping the side plastics in place. One of them also keeps the seat in place. I broke this bolt in the socket.
How do I get it out?
Where do I buy a new, identical bolt? (I dont want mismatched bolts)
Hope you guys can help. I am sort of a noob when it comes to this.
Here is a picture:
https://i.imgur.com/KfFEpzD.jpg
Here is a picture:
You need a bolt extractor, commonly called an easy out.
Once you get one, there are some tricks to getting it to work correctly.
A machine shop could do it for a few bucks or a six pack of beer, but it's good to know how to do it yourself.
If you go the easy-out route, be patient and careful. If you think you have a problem getting a broken bolt out, you'll have much more fun trying to get the broken bolt and broken easy-out removed. I hate the tradition easy-outs. I like the version that has a drill bit sized for the bolt, and then you tap a splined shaft into the drilled hole in the broken bolt. They work tons better than the old fashioned reverse screw type.
Trackside bolt kit. You get a bunch of hardware for the price of an OEM bolt.
The 6mm X 1.00 bolts that hold on most of the plastic are nothing special. And if you're concerned with matching bolts, just buy a set of 6mm X 1.00 bolts with the same heads at a hardware store that have the same length as the OEM units. While I don't want my bike to look like crap, I'm not too concerned about show quality of every nut and bolt on the bike. I doubt anyone will notice that one of your plastic's bolts is a 10mm head while the rest of them are 8mm.
As bradluke0 mentioned: take the seat off and you might be able to just spin the bolt out. With that kind of break the bolt isn't stuck, it was over torqued and the head tore off.
Last edited by ol'klx-er; 06-19-2013 at 08:31 PM. Reason: missing word and more info
![Big Grin](https://www.kawasakiforums.com/forum/images/smilies/biggrin.gif)
