I like being different, B.G. endcap change.
Old 12-27-2006 | 02:46 AM
Default I like being different, B.G. endcap change.
Hey guys, finally got my 606's mounted up, and all the bearings in the swing arm greased and got it all back together. Piece of cake.
Well my big gun end cap started faded pretty bad, so i was thinking of what to do, i was going to paint it with header paint so it looked good. then i thaught why not just sand it all down, i was gonna polish it but i thaught if i scratched it or something id be pissed, so i just went with a brushed look. I started with 150 grit sandpaper, went to 220,320, then 400. I like how it turned out, ill get the red out of the screw holes in a bit, but i thaught id show you guys how it looks... i like it... o and a pic of the tool box i use
Old 12-27-2006 | 03:02 AM
2k1w=no$'s Avatar
Default RE: I like being different, B.G. endcap change.
End cap looks a lot better. I like the way the bg looks but never cared for the red end cap. How hard was the anodizing on it, we get stuff anodized at work that 220 grit sand paper won't hardly scratch.
Old 12-27-2006 | 03:28 AM
tremor38's Avatar
Well, evidently BG's 'anodizing wasn't all that! I like the new look, EMS. You won't have to buy ointment anymore either
ORIGINAL: 2k1w=no$
I used a high speed wire wheel on a bench grinder to get it off,, came off in less than 3 minutes... and i used a smaller wire attachment on a high speed drill for the inside of the endcap.... i spend like an hour sanding it...
Old 12-27-2006 | 04:24 AM
DirtSurfer's Avatar
The end cap,tires and bike in general look great!!
Looks like your ready to rock in Florida!!!
Good luck man, take lots of pics!!
Old 12-27-2006 | 05:06 AM
Awesome man!!
Old 12-27-2006 | 12:50 PM
Thanks... ill try to take as many pics as i can.
Old 12-28-2006 | 05:37 PM
kv4's Avatar
kv4
I wonder how well a sand blaster would work. I used one to put a satan finish on a knife I made and it worked well.
Old 12-28-2006 | 05:41 PM
I think you would have to be careful, the wire wheel was taking the alum off... i had to watch, the steel wires were rippin right into it... so i would imagine sand blastin would do it too... unless its not that hight psi.... but you would have to be real careful. im sure it would work.
Old 12-28-2006 | 11:02 PM
ol guy's Avatar
I don't know about alum, but sand blasting mild steel makes it brittle. Asafe way , maybe would be to have it soda blasted. I believe the reason is soda does'nt get the metal as hot and work harden it.
Quick Reply: I like being different, B.G. endcap change.
