howdy all!! jet kit..
havent been on here in a while so i cant quite remember what i need..soo i figured i would ask the rest of you!
so i got a klx250sf with a slip on exhaust and it back fires a little bit so i figured i should order a jet kit for it. what kit do i need to get?
soon after i do the jet kit i will also get a new header, air filter, and do the airbox mod. that is pretty much all the performance i will do for a while untill i get the big bore kit, but that isnt in the near future.
so what kit? thanks guys!
Curious, why does everyong say "ordered a Stage 2" when it's the same part number from Dynojet?
I'm specifically referring to the KLX250SF. Part # 2182
https://cart.jetkit.com/p-1580-jet-k...-klx250sf.aspx
I mean, it's the same since the instructions mention what "makes" it Stage 1 or Stage 2...
http://www.dynojet.com/pdf/2182.pdf
For the 2009+ bikes the dynojet kit is a stage one/two kit. You don't have to choose. The only difference between stage 1 and 2 is the size of the main jet you install and the kit comes with quite a few.
