How would this carb mod work?
found these instructions on another site.. how would getting rid of the needle hole and vaccum hole in the slide on a CV carb actually work..can anyone explain this...
Tuning it up
In standard from the KLX is heavily restricted, so here's the hot set up to make the bike perform in the manner it was supposed to. First of all pull the carburettor slide out and fill the two holes drilled in the top with epoxy resin or similar and smooth off so that it doesn't snag in the body. Alternatively fit a new slide without holes, Kawasaki part #161261382. Remove the airbox snorkel and the spark arrestor in the end of the exhaust. Finally, go up three teeth on the rear sprocket. The result is an extra seven PS and more power everywhere. Sorted!
Tuning it up
From what I've heard, the Ausie and Asian bikes have a different slide than the one that comes to the US and Europe. I'm sure that you wouldn't want to fill the hole that the needle goes through.
Ride on
Brewster
Ride on
Brewster
I believe Westoz has done it with good results.
I went straight to pumper.
mod
Yep plug the holes with iguana purple poo. But if you can go pumper. Do a search and results shall be forthcoming. Funny though you Aussies get the bigger exhaust outlet yet the more restricted carb, turn around is pay around I guess.
DirtSurfer
03-25-2018 07:26 AM
CousinLarry
07-03-2012 02:30 AM
kx slaughter king
Ninja ZX-1100R
07-20-2008 11:34 PM
