how too...
Try a slip-on/full system, a 13-tooth sprocket, jet/filter kit, and smog removal/free mods and you'll be amazed what 4 more horse does for this bike.
what he said. this is a low power, heavy trail bike. it can be hopped up a bit, but personally i've stopped after over $700. Add $900 for a street wheel setup to that...it adds up and I'm not much over 20 horsepower.
If you want to get the wheel up, you're going to have to dump the clutch a bit and that's the bottom line.
Alot of people report a better feel of snappyness from the bike with the throttle cam, basically just a new twist throttle that opens up all the way with less twist of the wrist. Makes the bike feel faster, and more responsive, when it's just really the more comfort of twisting the wrist less. Can't remember what it's called, I'm sure someone will chime in with the brand name.
For front wheel lofting, I would go with a slipon. For road riding, I would go for a full exhaust.
Can you explain the reasoning behind this? I thought a full system was better all the way around.
Back pressure should help the bottom end. There was a huge bottom end difference when testing the inserts in the Big Gun. The smaller insert (read "added back pressure") improved the "wheelie factor" of the bottom end.
The gearing is very cost effective. I bought the 13T for Under $10.
As already mentioned the Exhaust and jetting are a huge plus.
Then you need to open up the intake (to get the most of the exhaust mod)
With the mods I have done I can get the front end up about 8" from a 2-3 mph roll-on crack of the throttle.
Second gear roll-on wheelies are probably a not for our heavy bikes... imo.
Hope this helps.
Hope this helps.
good stuff already mentioned, but I can't emphasize enough the importance of a good rear tire. w/o it, it just doesn't get much traction. the bike is heavy as stated, and thus makes it harder to get traction as it just gets lost in the rear tire spinning it away. at least that has been my experience. good luck with your experiment. ;o)
The slip-on's, with the stock header, give a better low end torque, where as with the larger headers of the full systems, little backpressure and not so much low end torque, but better high end HP.
As far as performance between the systems.. I don't think there is much, if any difference between say muzzy's, big gun, fmf.. It's all just personal preference, noise and looks.
I might venture to say the higher end gains are better than the lower end gains. I'd rather have a higher gain on the highway and the trails. You need to keep the RPM's up on this bike anyway. It's a 250! Wring it's neck!!!
