How often you change your fuel line n filter
So weather getting nice and wanted to ride a bit.. I tend to over do things so.. I changed my plug “ I do that every year” It’s cheap... and decided to change my fuel filter.. when I disconnect it from the petcock.. The line was hard and stiff/brittle
It’s been 2 years since I replaced the in line small little clear aftermarket filter.. just seeing how often you guys change yours?
I don't use an inline filter...never have. Mine is an '06 with many miles on it. I haven't used an inline filter on a bike since my first bike in 1970.
You're right about the fuel line hardening. Eventually they all do it, but probably the ethanol in the fuel quickens the pace. The fuel line material over quite a few years that's lasted the best for me has been Motion Pro...the gray stuff. It seems more resistant over time to UV, ethanol, engine heat, and just fuel in general.
I've been using the inline filters, but you have to watch them as I've heard some of the cheap plasttic ones dissolve and get soft after awhile. You'd think they'ed be fuel proof..lol
I 2nd the Motion Pro line, it holds up well and doesn't kink easily. Not exactly cheap, but not likely to leave you stranded somewhere (or in a ball of flames).
As for when I change mine... not very often. I tend not to think about it until something is leaking, LOL
However, I've seen it induce a funky color change in many plastic gas tanks and attack those plastic fuel filters. Some components seemed prone to reacting to ethanol and some don't. You never know for sure.
I do notice that you shouldn't let it sit idle very long without stabilizer for obvious reasons. Stabil and Berrymans fuel stabilizer has always worked in all my lawn equipment and anything else that's going to sit awhile. I've heard people claim that E-gas will eat up carb parts and such, and I just haven't seen that in any of my stuff over the decades that E-gas has been in existence.
I think in those cases where corrosion and damage did occur, it was after untreated E-gas sat in the fuel system and even dried up for the most part, causing the green fungus, pitting, and other horrors that can happen in worst case scenarios.
