How lubed are you?
How lubed are you?
If you grab your chain with your thumb and index finger and flex each link in opposite directions, how much should it give?
Mine sticks a little. I clean and lube my chain after dirty rides and just every few rides if it's just street.
Is this just dependent on tension? If there was no tension maybe it would be really loose and not stick at all?
I think the previous owner and the dealer had some sloppy lubricating and oil work done. There is oil splatter and crap all up in there that I can't get out with regular car wash soap. One of these days I'll have to do a complete drive chain assembly cleaning.
Which brings to mind, are there motorcycle cleaning services? I'd pay $30 for a spotless clean, lube and wax.
A pressure washer really cleans them up nicely. It's a good idea to clean the stuck on gunk off the chain then lube it good. I get my Dupont at Lowes too...Best price I've ever found. You chain will last a long time. I had to adjust my chain once and it hasn't stretched since. The harder you ride it the more it will stretch. There are specs in the manual for measuring the chain for wear.
markmeinteil
09-11-2006 07:06 PM
Icantrideabike
07-23-2006 04:28 AM
Scrtsvc
12-23-2005 04:06 PM
