How to lower my 2009 KLX 250s without link
Old 07-12-2012, 11:10 PM
diggity's Avatar
I got a 1.125 inch lowering link from kouba link (KLX3 model). Love it. Considering lowering the front too.
Is sliding the forks up the triple clamps wicked easy? Just loosen the bolts, slide em up, measure (kouba recommends only 0.5" with stock handlebar risers), and tighten? What is the torque setting? Any advice would be great. New to bikes but work on my diesel truck alot.
Thanks, Dave
Old 07-13-2012, 05:05 AM
Lotrat's Avatar
Yeah, it's that easy. Top clamp bolts are 15 ft-lbs. Bottom bolts get 18 ft-lbs. Thats on a 2009 and newer anyway. Probably the same for yours. I pushed mine up til they almost touch the handle bars.
Old 07-15-2012, 01:39 AM
diggity's Avatar
Thanks Lotrat,
To the OP. I hope this is helping you too
One more question Lotrat. I got one fork to slide up but the other is stuck. I tried tapping around with a mallet and running with the bike and hitting the front brake but no luck . Can I use wd40 or liquid wrench in the clamp areas?
Old 07-15-2012, 01:51 AM
TNC is offline
Originally Posted by Lotrat
I used the 1.5" lowering links. Here's some info from when I did mine: https://www.kawasakiforums.com/forum...e3/#post469281
This is definitely the way to go. Too much sag and the bike will handle badly, much less the suspension sucking. I like mine the way it is, but links are really the best way to drop it.
Old 07-15-2012, 02:34 AM
Lotrat's Avatar
A little WD won't hurt. It's easier to do it on the ground so you can use the weight of the bike to help slide them up.
Old 07-15-2012, 03:39 AM
TNC is offline
Thanks Lotrat,
I keep a couple of medium sized common screwdriver blades for this purpose...old screwdrivers that I've cut the handles off and the shaft at about 4". Now, you don't go crazy with these things, but you gently tap them into the upper and lower clamp splits just a little bit...repeat...just a little bit. The fork tubes should rotate out with some ease at this point. Nylon disc brake pucks for mountainbikes would probably work well too if one was too squeamish for the screwdriver blades.
Old 07-16-2012, 12:15 AM
diggity's Avatar
Sweet, the screwdriver trick worked. I got it done. Cheers, Dave
Saddlebronze
10-05-2008 06:52 PM
Saddlebronze
09-28-2008 03:01 AM
JonnyD
07-22-2008 01:24 PM
speedyjim
07-01-2008 02:16 PM
tremor38
05-27-2007 08:22 AM
Quick Reply: How to lower my 2009 KLX 250s without link
