HOW TO: Chain removal and installation
Old 07-06-2007 | 02:12 AM
03rubicon's Avatar
Default RE: HOW TO: Chain removal and installation
Great job, now can you do a blow by blow for all the carb work you guys talk about?
Old 07-06-2007 | 01:36 PM
tremor38's Avatar
That's a bit off subject, but go to the HMF website, go to the forums for off road and find the one for the KLX. There is a detailed explanation of the CVK carb mods with accompanying images.
Old 07-06-2007 | 08:53 PM
03rubicon's Avatar
What is the HMF website? thanks
Old 07-07-2007 | 12:01 AM
tremor38's Avatar
ORIGINAL: 03rubicon
Here's the link. Just keep reading the thread. It's good info.
https://hmfengineering.com/forums/showthread.php?t=1617
Old 07-07-2007 | 12:28 AM
hokie01's Avatar
Tremor that is a great thread,as simple as it is to remove a carb this step by step makes it seem easier.
Old 09-03-2007 | 10:40 PM
Mtns247's Avatar
Great job. You mentioned you added the 13t front sproket. Did you have to use aspacer? I have a 13t but it doesn't look like it fits. The stock 14t has a spacer built in that keepsthe chain away from the engine.I can finagle a spacer in therebut was curious what everyone else did?
Old 09-03-2007 | 11:31 PM
LearjetMinako's Avatar
oh sure, now somebody makes a picturiol of chain removal. Just two days after I did mine.
Now I'm left cocerns about mine. Did I put the click in the right direction? Did I put the "S" facing outwards? I know lubed it afterwards, in fact 3times in the last 3days. It should be fine, the chain just survived 30miles of grueling rough trail riding.
FYI: Gasoline work wonders on removing dirt and grim from a dirty chain. Just let it soak in a oil pan with about 1-2pints of gasoline and use a brush to clean between the links. Then let sun dry for 5-10minutes and lube with favorite chain oil.
  #28
Old 09-03-2007 | 11:39 PM
TypeSH's Avatar
Sounds like you have the wrong sproket. The correct sprocket will have the spacer just like stock.
  #29
Old 09-04-2007 | 04:10 AM
stellar_d's Avatar
I got the sunstar, it doesnt have a spacer like the stock but it had a shoulder to keep distance. maybe you would call this a spacer. it works perfectly though.
  #30
Old 09-04-2007 | 02:11 PM
ORIGINAL: LearjetMinako
Actually that thread with the pictures was posted almost a year ago to the day. People there is a search feature where you can look for a thread or phrase or even a single word and then if you are fairly sure it is in the 250 section then you can narrow the search down to that. Come on people start using the search. Then if you can't find something give us a shout. But we are getting way too many double and triple threads going on the same subject. A lot of footwork has already been done. Give it a try.
Quick Reply: HOW TO: Chain removal and installation
