How to adjust idle mix screw while carbs on the bike
Fixed the clutch cable buttt....
I dont know how people adjust idle with that screw when changing altitude, I cant for the life of me get the idle right. Its either dying or heating up my coolant so high its running the fan on the rads and also not idling right. I spent a good 2 hours at it already.
I think I'm just going to take it to a local shop and ask them to do it and also maybe do a full mechanical inspection while I'm there.
Ahh, for all you guys wanting to re-adjust the fuel screw "on-the-fly", I am wondering what you think you're accomplishing... The fuel screw controls the AFR you get from the pilot circuitry, which only fuels your bike at idle up to 1/8th throttle (just off idle) and during deceleration..
on another note, is there something I'm missing when adjusting the screw. because you have two things to play with. the idle speed and idle mixture screw. which do you play with first and what are you looking for out of each? If i change the idle speed screw I can hold rpm kind of... it will stick at 4000 or 3000 or 2000 and then slowly come down to 1000 then 900 then die.
Could it be that I dont have a large enough pilot jet? I wouldent think dynojetting a carb would lead to that problem though? its probably more for big bore?
Looks like im riding the pedal bike tomorrow haha
When I had the cvk, I'd adjust the pilot screw when I did a big elevation change, from 3,000 (where it's tuned) to 8,000+ feet. A lot of my trail riding, especially at elevation, is between 0 to 1/4 throttle. It accomplishes quite a bit with improved snap and better idle.
The problem I think is that the guy who had it before me put a dyno jet kit in even though I dont think that should affect idle?
maybe I need a bigger pilot? I have the screw out around 3 turns or maybe a bit more.
Heres a video of it idling and reving if anyone wants to watch lol
