Honda crf250L.....
#101
when my valves were out of spec...twisting the throttle back and forth while pushing the start was the only way it would start and required a long warming with choke out (nearly minute or longer)....yes, you are not suppose to twist the throttle on the klx250 from what i was told my a mechanic (flooding the carb and wet the plug he said)...
#102
#105
I find that during a hot start to roll the throttle slightly while cranking; it fires up straightaway. First/cold start, pull the choke out 1/2 way, let it fire and although it idles gingerly, it will not stall. By the time I put on my helmet & gloves it accelerates through the gears without flat-spotting. If it has been sitting for a few hours, it's KACR lotto. Sometimes it fires straightaway if it doesn't choke is required.
#107
I hold the choke while cranking and then release it when it fires. It also stops the engine racing to 4,000rpm when the choke is fully pulled out.
#108
![EEK!](https://www.kawasakiforums.com/forum/images/smilies/eek.gif)
motif
10-30-2015 09:45 AM
trev0006
03-21-2010 11:39 AM
