High Elevation Jetting
If you want to know some of the physics behind the rejetting conundrum:
the percentage of oxygen is essentially the same at high elevations when compared to lower elevations (20.9% o2), it's the PRESSURE of the atmospheric gases that is lower at high elevations.
So, when your piston gulps air on the intake stroke at high elevation, there is not as high a pressure gradient across the intake valve; with less pressure gradient, there are fewer total air molecules that make it into the combustion chamber. So, although the piston is pulling hard enough to get about it's normal amount of fuel pulled into the combustion chamber, there is less air pulled in on each intake. The result is the mixture is "richer" as you go up in elevation. That's why people run smaller jets when all they ride is Pike's Peak, compared to those riding around Death Valley (a couple of hundred feet BELOW sea level).
Blackheart58 is correct our atmosphere is 20.9% O2 everywhere, if you multiply the total atmospheric pressure by 20.9% you will get the pressure of O2 available in any given situation. This will explain the problems encountered with changes in elevation.
Very interesting, on the "thin air" . So, at sea level, if you take a deep breath you will actually be able to inhale (with the help of the higher atmospheric pressure) a larger volume of air, compared to the volume of a deep breath on a 10,000 ft mountain top in CO.
I'm just asking because the "thin air" is very noticeable to anyone who travels to higher altitudes. This also makes me wonder what goes on when people acclimate to the higher elevations. Interesting stuff.
Dan
Dan
#30
http://maps.google.com/maps?q=38.819...,0.066047&z=15
the first week we are staying in a camper in a couple places.
http://maps.google.com/maps?q=38.080...,0.166168&z=13
http://maps.google.com/maps?q=39.327...,0.004117&z=19
