Help with raising forks / handlebar
Old 06-16-2016 | 09:10 PM
Narfle's Avatar
Default Help with raising forks / handlebar
Bought a used 06 250s. Came with a Moose Racing handlebar and lowering links on the side. Got home and did a ton of mods to the bike and the last was lowering links. Problem is the forks can't be raised enough to lower the front end to match the back because they hit the bottom of the bars. I installed the Moose bars hoping for some reason the different bend would give some more room but nope. I'm about 10mm short of the height I need. Can someone give me some quick options? I'm sure a ton of people have dealt with this same problem...
Thanks
Old 06-16-2016 | 10:33 PM
Brewster's Avatar
You should find something here that will work:
https://www.rockymountainatvmc.com/t/982/Clamp-Kits
Just make sure the tire clears the fender when fully compressed.
Ride on
Brewster
Old 06-18-2016 | 04:48 PM
Narfle's Avatar
Perfect thanks, saved me some time appreciate it-
Old 06-19-2016 | 12:44 PM
MaximusPrime's Avatar
I used a Bikemaster bar riser kit.
It was ~$35. Can raise the bars up to 2" IIRC. It has multiple riser plates to get just the height you want.
Old 06-20-2016 | 08:34 PM
GBAUTO's Avatar
+1^^
This is the kit I use on mine. Just make sure that the cables don't bind and all of the wiring and hoses are not in a pinch.
Narfle
12-15-2015 08:33 PM
Sail-A-Wai
12-06-2008 03:47 PM
foggys916
10-05-2007 05:24 PM
queenpdog
10-11-2006 03:52 AM
bkyee
Ninja 500R
09-04-2006 11:17 AM
Quick Reply: Help with raising forks / handlebar
