Help with mods please
Old 02-24-2008 | 01:41 PM
Davebert's Avatar
Default Help with mods please
Ok, I have decided to mod my wifes 2006 KLX250S and here is what I plan on doing but want to be sure I have done my homework correct. I am going to do it this way to save money and get a good power boost. I have already done the 13t sprocket but that is all so far. My plans include:
KLX300 Exhaust and head pipe
KDX200 Snorkle
# 16009-1912--------Needle-Jet,N1TC
# 92143-1667--------Needle Collar (required for N1TC needle)
# 92037-1401--------Clamp, Needle Jet (Clip, required for N1TC needle)
Not sure on the correct jet for Florida panhandle about maybe 200 feet above sea level
# 92063-1069--------#125 Main Jet
# 92063-1074--------#128 Main Jet
Extended Fuel Screw from Kouba #FS-3
Using stock pilot jet
Drill slide to 7/64's
Any advice on the main jet size to use? I am thinking the #125. Also the correct clip position on the needle? Anybody do the same setup?
Thanks in advance,
db
Old 02-24-2008 | 01:52 PM
2k1w=no$'s Avatar
Default RE: Help with mods please
Imo, I would not spend the money on the kdx snorkle. Either ditch the lid all together or take the snorkle out. If you want the snorkle I know some on here have ones that they are not using, you may get it for cheap. I would get a high flow air filter like a uni, or twin air though. Don't forget to open up the crank case breather.
Old 02-24-2008 | 02:15 PM
Davebert's Avatar
I already put a UNI air filter in it (forgot). I will be happy to get some offers on a snorkle The crankcase breather mod. Does it help performance that much?
Thanks,
db
Old 02-24-2008 | 02:30 PM
2k1w=no$'s Avatar
ORIGINAL: Davebert
No idea, but I did mine.
Old 02-24-2008 | 02:39 PM
stellar_d's Avatar
I agree with 2k, the snorkel is useless, I'd ditch the lid and go with the bigger jet.
Old 02-24-2008 | 03:01 PM
Davebert's Avatar
ORIGINAL: stellar_d
Ok, so you mean go with the #128 main jet? What clip position on the needle? I am at about sea level over here too...
Thanks,
db
Old 02-24-2008 | 03:09 PM
stellar_d's Avatar
yah sea level i'd go 128, seems the popular choice. I think most guys go with the 2nd position on the clip, but i'm not sure i run the dynojet kit. the needle position is something you can fool with a little easier too.
Old 02-24-2008 | 03:15 PM
Davebert's Avatar
Ok, thats what I wanted to hear. I see pulling the carb would get easier each time its done but I would like to do it one time. So you can reset the needle clip without pulling the carb correct?
db
Old 02-24-2008 | 04:50 PM
stellar_d's Avatar
you bet...take care you dont strip the screws though, as it will be at a funny angle. at least it was for me.
Old 02-24-2008 | 05:01 PM
Sid Post's Avatar
The 128 jet is richer then the 125 isn't it?
In the Arizona heat of summer and the lower temperatures of winter, is a 125 jet a better choice for me?
Thanks!
Quick Reply: Help with mods please
