Help lowering front
Old 03-27-2012 | 12:03 AM
lj-rubi's Avatar
Default Help lowering front
Installed lowering links and bar risers today and attempted to raise the forks in the triple trees, but they don't seem to want to move? What am I missing? Loosened the three bolts in the clamps on each side and pried the gap open a little to try to get them to slide but no go. Figured I would ask the experts befor I screw something up. Help!!
Old 03-27-2012 | 02:34 AM
BillMoore's Avatar
What year is the bike? On my 2010, there are only 2 bolts on each side, and once loosened, the forks easily slid up.
Old 03-27-2012 | 02:42 AM
BleednGreen68's Avatar
Do both forks at the same time. Probably binding up. I've seen the tubes and clamps get kind of frozen together from corrosion from water or dirt might be binding them up. Use a rubber mallet.
Old 03-27-2012 | 03:10 AM
ahnh666's Avatar
I used my moto jack...put a towel between the fork and bars...lowered the jack...pop!...became unstuck...
Old 03-27-2012 | 04:00 AM
So the upper and the lower clamps are loosened?
Old 03-27-2012 | 11:17 AM
doum's Avatar
If both side are loosen and it's not moving, try removing the front wheel.
Maybe you tee moved, you coud also try loosening the upper tee.
Old 03-27-2012 | 03:18 PM
lj-rubi's Avatar
Upper and lower clamp bolts are loose but I think that the clamp is just stuck to the fork tube. I just wanted to make sure there wasn't something I was missing before I got more agressive to make it move. I will put a little pressure between the handlebar and the top of the fork tube tonight and get it broken loose, then it should slide down...I hope. Thanks all! BTW, it is an '07 that is new to me.
Old 03-28-2012 | 01:15 AM
lj-rubi's Avatar
Got 'em moved, thanks all!
afboundguy
04-26-2008 07:08 PM
afboundguy
05-14-2007 01:25 AM
bryantjt
01-19-2007 02:05 AM
KaSixR
ZZR 600
06-06-2006 04:55 AM
05_ZX636
09-30-2005 05:48 PM
Quick Reply: Help lowering front
