HELP! Getting poor fuel mileage
Old 01-16-2012, 09:51 PM
Landon's Avatar
Ok. I got the bike put back together. Rolled her out the garage and started her up with choke to let er warm up a bit before I headed to the gas station to fill up and go for a ride. I had some gas at home so I probably put a half gallon in to make sure I would not run out before getting to the gas station. Got on the bike and headed down the road, the bike ran fine for about the first mile where I rolled off the gas for a 90 degree curve in the road. As I gave er some throttle in the middle of the turn the bike just died. I could start it up with or without choke and it would idle just fine, as soon as I gave it throttle it would die or try to die. I pulled the choke and nursed it back to the house. What did I do wrong? I am thinking something with the diaphram???
Probably something stupid I did.
  #52
Old 01-16-2012, 11:12 PM
2veedubs's Avatar
Sounds like the needle clip fell off and your needle is not rising with the slide. Happened to me along time ago on my XR185.
  #53
Old 01-16-2012, 11:14 PM
Or, if the needle is not rising, could it also be that the diaphragm was ripped or not installed correctly, and the vacuum isn't building to raise the needle?
  #54
Old 01-16-2012, 11:21 PM
2veedubs's Avatar
Would that situation kill the motor all together or just limit your rpm's.
  #55
Old 01-17-2012, 12:28 AM
redpillar's Avatar
Nothing is stupid if you are working on your own bike. It is called a learning experience
  #56
Old 01-17-2012, 12:56 AM
Landon's Avatar
I have the stock needle which does not have a clip.
  #57
Old 01-17-2012, 12:59 AM
Landon's Avatar
For some reason thats the first thing I thought. The diapharm was kind of a pain to get back in the grove, so I am wondering if its not in there right and as you said the vacuum doesn't raise the needle. Since I can check that without removing the whole carb, I think thats where I will start. The jets are all basically new, so unless something came from the tank then I wouldn't think it would be a plugged jet.
  #58
Old 01-17-2012, 01:01 AM
Landon's Avatar
True, I am definately learning! At least its winter and its not the best riding weather.
  #59
Old 01-17-2012, 01:23 AM
Landon's Avatar
I am pretty new to this, but I don't think it will kill the motor if the diaphram was installed wrong or torn.
I came across this video and the diaphram does not react till the throttle starts to open.
CV Carburetor - YouTube
  #60
Old 01-17-2012, 03:10 AM
2veedubs's Avatar
Right, the throttle cable only actuates the butterfly. The engine dictates how much the slide opens via vacuum.
Quick Reply: HELP! Getting poor fuel mileage
