Help Front Sprocket stuck
Im stepping down to a 13 tooth on my 2007 klx250s, the bolt seems to be stuck. Anyone have any ideas on how to remove this bolt to get the stock sprocket off. Any ideas would greatly be appreciated.
Thank you
Thank you
Impact wrench, or a large breaker bar. Also make sure you moved the lock tab(#92200).
http://fiche.ronayers.com/Index.cfm/...p/Transmission
